shocks for 318ic
  • tdoyle
    • Oct 2009
    • 40
    shocks for 318ic
    I bought some m3 springs to put in my 92 318 vert. I cannot figure out which shocks to use. No one seems to list Bilsteins for this car?
    I found some KYB, and Gabriels, and Sachs/Boge.
    Can I use Bilsteins from a 318is?
    Will the car take a 51mm cartridge?
    What other parts do I need for the job?
    Thanks!
  • 3bvert
    • 1032
    didnt that link work for cheap billy's, hes got em
    yes the shocks form a 318is will work
    here is the billy site http://www.bilsteinshocks.com/bilste...W'&model='318i All Models'&year='1992'
    hows the lower control arms, youll be popping them off the ball joint, top bearing mount, replaced mine, figured why not wiht 150+k on them
    then agin I was doint the whole suspension, control arms, cabs, springs, tie rods, rotors, brakes so why stoip at the top bearing
    dpendiong on the miles adn use/abuse of your car you may need new spring pads too, you can see them and acess their condition before pulling stuff apart, and order if needed,, I did not need
      • 37833
      Any stock style shock is fine for M3 springs.
      Grover Beach, California
      BimmerHeads.com
      • Hey-U
        • Mar 2008
        • 560
        No problem using 318is billies on your 92. I have this set up with Eibach and it works fine.
