Hate my IE Stage 3 Reverse Rake
  • a32guy
    • Mar 2005
    • 183
    I hate cutting coils but I had to cut one up front... didn't seem to do enough. Anyone else running IE3's that look a little better?
    I'm probably going to go with H&R Race. Suggestions?
  • whiltebeitel
    • Apr 2007
    • 2098
    Still running stock strut mounts?
    '89 325i track sloot
    '01 530i daily
    -Enginerd
    • deutschman
      • May 2008
      • 5958
      +1. changing the strut mount and/or taking the spring pads out might help. i also don't know when you installed the springs but they also need to settle into place a bit... they will get a bit lower in time.
      • a32guy
        • Mar 2005
        • 183
        Yes, everything is stock. IE3s and Bilstein Sports have been installed for about 3 weeks now.
        I guess my next step is to extend my upper spring perches? I just don't feel like it will be low enough still. :(
        • Colorlesss
          • Jul 2009
          • 570
          did you really expect a non-adjustable kit to slam your car ? if you wanted it perfect you should have gone coilovers.
          • a32guy
            • Mar 2005
            • 183
            No I didn't expect it to slam my car. I expected a decent stance, not reverse rake.
            • slo325i
              • 417
              just cut another half coil.... haha
              '89 325i - Totaled... good bye my love...
              '87 327i budget stroker - SOLD!!!
              '92 240sx - ca18det powered drift toy - SOLD!!!
              '89 325i - coupe - NEW daily
              '96 Audi A6 Quattro- Grocery getter/baby hauler
              '99 Busa - weekend wheelie monster
              • Holland
                • Nov 2008
                • 7212
                H&R Race
                Originally posted by DEV0 E30
                • Colorlesss
                  • Jul 2009
                  • 570
                  should have looked at other peoples pics. they almost always have that effect.
                  also. your euro side markers are not right at all.
                  • a32guy
                    • Mar 2005
                    • 183
                    PO install.
                    • theox69
                      • May 2008
                      • 1732
                      GC camber plates lower your car 24mm in the front -- that's almost an inch.
                      You can do that, and stack some spring pads in the back and that should take care of your reverse rake problem.
                      I suggest getting the camber plates with the H&R race though ;)
                      you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
                      • a32guy
                        • Mar 2005
                        • 183
                        Excellent, thank you for your suggestion! I think I will do just that. :)
                        • E30SPDFRK
                          • 5715
                          The camber plates with the stock diameter springs won't go that low. They'll drop it a little but not an inch. H&R race will be the same in the front and higher in the back. The best way to fix it is to sell the IE3's and buy some coils for like $50 more. Or you could get some FK 75/50's if you don't mind a slightly softer rear end.
                          Byron
                          Leichtbau
                          • White325is
                            • Oct 2006
                            • 5947
                            yeah. For like a few dollars more you could have got ground controls with your own spring rates. I had my IE's for like one week before I pulled and sold them for something better.
                            • a32guy
                              • Mar 2005
                              • 183
                              I always heard the GC's didn't go that low? Is that accurate in your opinion?
                              Does anyone have experience with NEX coilovers? Seems like a good amount of E34 guys running them...
