so i did my outer balljoints the other day and its the first ones i've ever done without a cotter pin. i tightened them as much as i could. when i turn the steering wheel to the left or right it turns the nut and actually unloosens it. the nut turns and not the stud. should i drive around a little and tighten them? this just seems really unsafe. has anyone else had a problem like this?
no cotterpin on balljoints.....
Tags: None
For some reason the tapered shaft of the ball joint isn't seating in the steering knuckle. That could be as a result of the nut not being tight enough, or it could be that you have the wrong ball joints. If the jack trick and tightening the nut doesn't lock the ball joint shaft to the knuckle, I'd say the ball joints are wrong.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
No, The stud and nut should not turn! The balljoint is supposed the swivel when the steering wheel is turned.
Something is wrong. Did you make sure the tapered hole in the steering knuckle was clean and had no oil or grease in it. That has to be dry! Also the new balljoint stud need to be clean and dry as well. There should be a Torx female opening at the top of the balljoint stud. After ensuring everything is clean, dry, not greasy, try holding the nut with a wrench and tightening turning the stud with a torx bit.Comment
Hate to say it, but I agree. I tried to save a pair of crap ball joints on my last CA's. Wasted my time and frankly my money. It's worth the (what?, $125.00 or so?) for new CA's.Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
i just went and bought new control arms rather than mess with the ball joints.
but the po of my car hit something hard/large enough to bend the power steering pump bracket, so i figured they were worth it.Originally posted by BillBraskyThat's like Vlad challenging Chip Foose to a car painting contest.Originally posted by acolella76i'm pretty sure 'Phillis' is short for syphilis
1994 tercel, 5efhe swap, i/h/e
1984 t-type, 5.3/th350 swap in progress
My newest addition:
Rebecca Arlene, born 4/19/2013Comment
