Leaking Rack?
  • 87-325ic
    • Apr 2006
    • 1198
    Leaking Rack?
    when removing the rubber boots covering the inner tie rods, Should there be fluid from the racks gears in there?
    I took one side off and about a 1/2 cup of fluid poured out the boot. the other side had a torn boot, but no real amount of fluid.
    Is my rack gone?
  • PeaveyBassist
    • Sep 2004
    • 3511
    Should be no fluid. The end seals are leaking and you'll need a new rack unless you are able to find rebuild kit and have the experience to rebuild your rack.
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • Philo
      Ich esse kleine Kinder
      • 3334
      /\ I concur.
      If you are mechanically inclined, call around to some local salvage yards and score an E36 rack. Do a quick mod and install. Or you can always go with the E30 rack. Tie rods are the same on both.
      -tim
      Originally posted by Jordan
      I like the stance
      • 87-325ic
        • Apr 2006
        • 1198
        ill plan on finding an e36 rack to replace it with.
        i just wanted to be sure my current rack was in need of replacement first.
        i have a bad shimmy that feels like its from up front. replacing the half threaded on tie-rod improved this a little bit. but even with two new tie rods and only a few year old control arms, its still bad. plus i get a bit of play back and forth in the rack itself.
        but i think most of all, my old, mismatched used tires are the number one cause of my 55-60mph death shake.
        thanks
        • george graves
          • 20003
          What if I told you that you didn't need a new rack and could save all that labor and cost?
          And all you would need to spend is about $15 and 5 mins?
          Originally posted by Matt-B
          • george graves
            • 20003
            Get this stuff:
            Valvoline MaxLife® Transmission Stop Leak
            My rack was pissing fluid out constantly - I didn't have money for a new rack, so I just kept adding fluid. It got really bad. I was filling up the reservoir every day, and the rack would be grinding and out of fluid by the time I came home.
            After using cheaper and less expensive fluid, I gave this stuff a try. The first quart leaked, and I had to replenish it. But by the time the second one went in the leaking had stopped.
            That was 5 years ago. I still have the same rack. It hasn't leaked a drop since.
            You can thank me later.
            GG
            • 87-325ic
              • Apr 2006
              • 1198
              haha, thanks now!
              its not a leak that i have to keep adding fluid to.
              more so, its the free play in the rack that is the real problem.
              • scottinAZ
                • Dec 2009
                • 1312
                if the rack is leaking (as evidenced by the fluid you mentioned), and it needs new inner tie rod ends, its better to just replace it with a long rack (rack with boots and inner tie rod ends) Either E36 or E30, your call, but that should tighten up the front end for you.
                I saved 15% on my Bimmer parts by switching to ...
                • 87-325ic
                  • Apr 2006
                  • 1198
                  i just replaced the tie rods while i was there. i had new ones already.
                  thats when i realized the rack was in poor shape.
                  ill be looking for a decent e36 one.
                  • george graves
                    • 20003
                    Oh yea, the stuff in a can won't take up slack on a loose rack - sorry - my bad.
                    • 87-325ic
                      • Apr 2006
                      • 1198
                      thanks for the suggestion though, if i ever have a leaky rack. ill know what to use. im sure that would work nice for the pump too huh?
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        Another option would be to have a local rack and axle shop rebuild the rack for you, but a junkyard e36 rack would be cheaper and you'd get the improved steering ratio...
                        Project M42 Turbo
                        • 87-325ic
                          • Apr 2006
                          • 1198
                          so any e36 will be good? whats the best/ easiest?
                          • Philo
                            • 3334
                            Any E36. Best would be a 95 M3.
                            -tim
                            I like the stance
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Well that is a matter of opinion, the 95 m3 rack has the correct amount of travel so you will have the same steering radius but the z3 rack is a faster i.e. lower ratio rack than the 95 m3, some prefer it for auto-x. I also can attest to the effectiveness of the tranny stopleak working wonders, can't remember what brand but I was amazed at how bad of a leak it fixed.
                              '89 Alpine S52 with goodies
