Replacing my rack I hit a snag. The old came out fine following the Bentley procedure. Took a few hints from the e36 rack swap DIY, but hit a huge problem getting the new rack splined onto the knuckle. Still can't get the damn thing splined, any hints or tips?
Also, while trying to spline it, it disconnected from the inside of the steering column itself (32MM nut right in front of the firewall from the inside of the vehicle). If I spline the knuckle to the rack then the shaft into the 32mm nut is a pain/impossible to get reconnected. If I connect the two shafts (steering wheel column to the shaft that goes to thru the firewall to the knuckle) then the knuckle is totally stationary. I think connecting the shafts is the first step then tackling the knuckle>rack spline.
Any suggestions or tips? This was not supposed to take a day + at my buddies house. Currently my only form of transportation, so I'll be eternally grateful to any advice on this. I'll send 2 dozen of your favorite cookie to any winning strategy :D
It's a '91 318is and I purchased the rack from Joe318is who had used this rack previously in a '91 318is.
Thanks a billion in advance!
Christopher
Christopher
