HR Race + Billy sports + stock tires
  • pinoy325i
    • Dec 2009
    • 127
    how much danger would my oil pan be in with HR Race springs + bilstein sports + stock bottlecap tires? much appreciated. Godbless.
    1989 325i Delphin-Metallic
    Fueled by faith! :)
  • iamsam
    • Jun 2008
    • 174
    not much. Just don't straddle curbs.
    • pinoy325i
      • Dec 2009
      • 127
      i dont have enough funds to get everything + skid plate so im just worried about bustin the pan >.<
      Fueled by faith! :)
      • Philo
        Ich esse kleine Kinder
        • 3334
        I've had that setup for almost a year now and I have never had an issue with it. I hit stuff with my exhaust, but never the pan.
        -tim
        Originally posted by Jordan
        I like the stance
        • Aptyp
          • 6584
          i've never broken a pan, but a buddy of mine is on his 4th...
          it's up to you.
          • pinoy325i
            • Dec 2009
            • 127
            oh geez >.< he was on the same HR race + billysports setup?
            Fueled by faith! :)
            • Aptyp
              • 6584
              before then, I rolled around on Ebachs and Tocikos for 4 years and still never busted one. I scrapped once, but I was airborn...
              • pinoy325i
                • Dec 2009
                • 127
                well im gonna be running stock bottlecaps for a while till funds go up. doesnt that help? or no.
                Fueled by faith! :)
                • Philo
                  • 3334
                  Your wheel diameter should always be the same, so no. The height of a car is not adjusted by the wheel/tire combo (unless you're a VW guy). Either learn to drive, or don't lower your car. 90% of people who break pans are just careless drivers. The other 10 are just unlucky. If you're that worried about it buy the dampers and a skid plate and get the springs later.
                  -tim
                  I like the stance
                  • m3clutch
                    • Nov 2008
                    • 352
                    dude don't sweat it! i'm running HR race with billies. Before I put the volvo lip on, i had no problem getting into pretty much any driveway. Mind you you do have to take slight angle into some steeper driveways. I have only hit my oil pan once and it was a light graze when i was sliding in parking lot (immature) and went over a speed bump and straddle it for a second. You will be fine. The lowness will make you a more careful whether you like it or not. It's totally manageable. Do it!
                    Flickr
                    • JJe30
                      • 2044
                      I've had no issues. Been running H&R race almost 3 years now.
                      • B. Tyler
                        • 174
                        I have been running the Bilstein/ HR race combo for a few months now and I havnt even bottomed out over a single speed bump, much less gotten the oil pan on the ground. No worries at all. It's really not going to be that much lower in the front unless you are running camber plates with a shorter stack height as well.
                        • frankspinelli
                          • 71
                          good thread. im thinking about purchasing the same setup.
                          • Philo
                            • 3334
                            My H&R race w/ Bilstein sports should be up for sale around spring break. Coilovers here I come.
                            -tim
                            I like the stance
                            • 3bvert
                              • 1032
                              skid plate is cheap insurance and I often wondered just how close my oil pan was to destruction, I like the piece of mind
                              true it sits a little lower, but now , about a month after install it is showing a battle scar
                              scrape the exsaust occasionally
                              biggest pain in the arse I discovered the other day, finally got a lip, put it on, went to back down my ramps
                              no go, fu*k
                              other problem , is stock jacks wont get under the car, if you have a flat , and neither will my floor jack wihtout a flat, so plan on a solution
                              worth it all, love the ride
