I'm going through the suspension on my '88 sedan, replacing all the blown/rotted/fried/cracked/missing components and mildly upgrading at the same time. Car is a daily driver (and I'm talking major teenager taxi service stuff here) with occasional autocross use in SCCA STX class. Budget and comfort are my top priorities; cornering is desired, as long as it doesn't conflict with cushy & cheap. I'm very very old, so you 19 year old guys on coilovers and konis are on the opposite end of the cornering/comfort bell curve from me.
I inherited H&R sport springs from the PO. I'm going with KYB shocks, replacing every bushing and mount on the car with OEM rubber (voids filled with soft 60A urethane), 21mm front cabrio sway, Turner fixed front camber plates, and bottlecaps with 195-60-14 Azenis 615's that I got cheap. Might upgrade to 15X8 and 225-45-15 current-generation autoX tires at a later date if Mrs. Funcrew releases her stranglehold on the racing budget (fat chance).
So the missing piece is whether to upgrade from the anorexic OEM rear sway. I don't want to reinforce the trailing arms, so that limits rear sway size to something, I'm not sure where the line is, maybe 16mm? Stock bar is about the diameter of a coat hanger.
So should I try to source a larger rear bar, just keep the OEM and replace the rubber bits, or what? Anybody got one they want to sell cheap?
