Power Steering Woes - Wrong Fluid Causing Problems?
  • 95///M3
    • Mar 2005
    • 181
    I picked up an E30 this week and the power steering is so light that it is nearly un-safe. I can send the wheels from lock to lock from a standstill with one finger, nearly zero effort. If the previous owner filled the system with PS fluid as opposed to ATF could this be the cause of the problem?
    UPDATED with Video:
  • StereoInstaller1
    GAS
    • 22679
    No, but your front tires inflated to 400 PSI might become an issue
    Closing SOON!
    Thanks for 10 years of fun!
    • browntown
      • Jun 2004
      • 3524
      I think the steering is too light as well. I'm planning on getting one of these:
      As for your question, if the rack is full of power steering fluid, drain add atf, drive, drain, add more atf, etc. The thicker ps fluid should make more pressure in the lines and would likely cause a leak before it made your steering easier.
      • SpecM
        • Oct 2005
        • 4531
        the p/s fluid shouldn't hurt that much...
        all it is is undyed, overpriced ATF anyways. ATF is no thicker, although it does have better detergants and is better priced
        neither of which would cause what you have going on
        1989 cirrisblau-metallic 325i
        • 95///M3
          • Mar 2005
          • 181
          Updated with a video...
          • E30Kaiser
            • Mar 2008
            • 1790
            Dude is that on jacks or something? That looks crazy and unsafe.
            "We're not here for a long time, we're here for a good time"-Colin McCrae
            • browntown
              • Jun 2004
              • 3524
              Wow, I wonder if the pulley is oversize and the pump is running overtime. No idea, that's just crazy. If it doesn't have atf in it, change it and see if that makes a difference. Or just delete the power steering all together.
              • 95///M3
                • Mar 2005
                • 181
                I wish... It is overly powered. I don't quite understand it myself! Any thoughts?
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  Bigger accessories pulleys underdrive.
                  Ich gehöre nicht zur Baader-Meinhof Gruppe
                  Originally posted by Top Gear
                  Just imagine waking up and remembering you're Mexican.
                  Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                  • browntown
                    • Jun 2004
                    • 3524
                    ^^ you're right
                    • 95///M3
                      • Mar 2005
                      • 181
                      Consensus is that the most cost effective method of fixing should be to loop the rack, ditch the pump and reservoir?
                      • E30Kaiser
                        • Mar 2008
                        • 1790
                        I would go with that lol, I drive without PS fluid but all the stuff is still on there and it isn't terrible as long as your tires are pumped up.
