Removing CAB's
  • HarryPotter
    • Jan 2010
    • 3642
    Removing CAB's
    How in the hell did you guys get these off?
    John F. Kennedy
  • FredK
    • 14761
    3 jaw puller, or just cut them off. You can cut them out of their bores using a sawzall, carefully, or you can use a vise to press them out.
    • clydesdale
      • 631
      • scottinAZ
        • Dec 2009
        • 1312
        Yep some form of a puller yanks them off right quick. I used a 2 jaw that I had laying around, and had no issues with getting them off the control arms.
        I saved 15% on my Bimmer parts by switching to ...
        • u3b3rg33k
          • Jan 2010
          • 2452
          Round things come out of round holes very easily if you destroy the inner ring, and decrease it's circumference.
          I used a carbide bit, then yanked them right out with an Eiffel geared plier wrench.
          I recommend replacement with AKG bushings.
          Ich gehöre nicht zur Baader-Meinhof Gruppe
          Originally posted by Top Gear
          Just imagine waking up and remembering you're Mexican.
          Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            i used an air hammer, worked great
            -Andy
            • HarryPotter
              • Jan 2010
              • 3642
              I've got THR's going on so I'm not worried about anything, unfortunately there isn't a motherfucking power tool in sight in this fucking household. (pretty infuriated)
              John F. Kennedy
              • xwill112x
                • Jan 2009
                • 4236
                bfh
                • HarryPotter
                  • Jan 2010
                  • 3642
                  My buddies lettin me borrow his sawzall, shit's about to get ugly.
                  John F. Kennedy
                  • scottinAZ
                    • Dec 2009
                    • 1312
                    if you use a sawzall to get the bushings off, be careful around the pin end of the control arm, if you fuck that up, accellerated wear will result in the new bushings.
                    Other than that, I can see no reason a sawzall would not work just fine for this job.
                    • HarryPotter
                      • Jan 2010
                      • 3642
                      Ya I figured I'd have to be a bit careful around that part. I'm not worried about the lolipops though I'll probably just blaze right through that.
                      John F. Kennedy
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        Wait, you're cutting the lollipops off? That seems totally unnecessary.
                        • Lunner
                          • 222
                          Windex + Any jaw puller.
                          No need to get crazy here, it's just a rubber bushing.
                          87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
                          • HarryPotter
                            • Jan 2010
                            • 3642
                            Rented a 3 jaw puller from autozone, came off relatively easy. had to do it four freakin times though, rip off the lolis then the little metal bushing on the inside were next. Had to drill some tap holes in the back of the arms, all easy shit really.
                            Slid those THR's on without much trouble. Oh and I was gunna cut the lolis because I have THR's so I wasn't using them. But now I still have em if anyone needs a cheap set. They aren't damaged at all and look pretty decent actually.
                            No sawzall was used during this process.
                            Still havent driven the car still waiting for that kinda soapy water to dry. But will be lettin you guys know how they feel, i'm stoked to say the least.
                            John F. Kennedy
                            • idanity
                              • Jun 2006
                              • 775
                              GIGGITY !
                              3 pedal club
                              200,k+ club
                              cabrio club
                              port-matched- polished- purring www.BMWpark.org
                              </div>
                              linux since 1999
