1988 325iS
Ground Control w/ Koni(Shortened)
ST Sways
225.45.16 Tires
Vehicle will not be a daily. It will be driven quite frequently though. It will also see Auto-X as well as HPDE/Track Days/Potentially Drift. Just my 'motorsport' vehicle and fun vehicle to drive around.
What kind of spring rates should I be looking at? What spring rates do you run? What ride height with that rate? IE3 is 325/515 is I remember and I don't consider it stiff at all. Many are hinting I should be looking into 600ish front and 800ish rear. I know the rear of the E30 loses ~50% of the rate at the wheel due to the rear suspension design. Seems at that point with 600ish front rate would need more like 900-1000 in the rear if wanting to keep it more 'even'.
I am more experienced with an E36 in this type of setup so may thought could be off/incorrect and looking for guidance. Stiffer is not a problem. I just want it to stick, be fun to slide around and have a semi decent ride. Maybe the spring rates that I have been told or recommended are also too high. Maybe 550/750? So open to a discussion/reviews/etc. Seems that some reading on R3V that the 550/650 ballpark might be a much better starting point.
Thanks!
ST Sways
225.45.16 Tires
Thanks!
