This washer people are talking about, is it a OEM BMW part? Part #? Wouldn't mind ordering a pair with the drop hats just in case
Drop Hats.....
Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
Reading through 20 pages of back and forth. Seems everyone is running different suspension setups. Is there a noticeable result if you keep stock springs, stock struts, etc and change out to the E90 OEM drop hats? Debating whether or not to do this, or just buy H&R Sports and call it a day.
I use mine as a daily driver so just want to get rid of the horrendous wheel well gap in the front. Running 14" with an IS valence and lip.If I had to live my life over, I'd live over a Saloon" - WC Fields
Garage
1991 325i
1972 R75/5 CafeComment
Wheel gap's gonna stay with 14" anyways. H&R sports are a good dailyable height but look sorta goofy with 14's. Definitely better than stock height though. I put springs on before wheels and it definitely made me like the car more but wheels have been the biggest "look at my car and get stoked" purchase so far.Reading through 20 pages of back and forth. Seems everyone is running different suspension setups. Is there a noticeable result if you keep stock springs, stock struts, etc and change out to the E90 OEM drop hats? Debating whether or not to do this, or just buy H&R Sports and call it a day.
I use mine as a daily driver so just want to get rid of the horrendous wheel well gap in the front. Running 14" with an IS valence and lip.Comment
I’ve been searching the thread and forums to find a set of camber plates that will work with e90 drop hats, but can’t find much. I’m running Bilstein HD’s with H&R OE springs with e90 drop hats. Any camber plates recommendations? Thanks. - TomComment
On my last E30, I used a set of SPC camber plates with E90 drop hats - https://store.vacmotorsports.com/spc...ates-p208.aspx
Ground Control also makes a set of camber plates compatible with OE spring hats - https://groundcontrolstore.com/colle...nt=42803062531. I have a set of these and will be using them on my current E30, also with drop hats.Zelig the Zinno • 300k and counting
http://instagram.com/zelig.the.zinnoComment
