front alignment Steering wheel off center
  • 36brua
    • 689
    Ok what did i do ? 89 I. had all wheels off. fixed parking brake shoes left rear. adjusted P brake put wheels back on. drive car 30 +- mph OK . 60+ freeway steering wheel now needs about a 10* correction to right.
    visual chck- tires correct rotation, steering arms, CAB, rack all look good. all components are fairly fresh. ideas ? just have alignment chked or ? thanks:???:
    My CA legal M60 swap
    The happening in our garage
  • Simon S
    • Oct 2004
    • 3758
    Not sure what caused wheel to be off at speed.(?)
    Might be a good idea to take it in for an alignment - for sake of tire life if anything.
    Otherwise, steering wheels aren't too hard to remove and re-center.
    Disconnect battery for ~30 min+ to disarm airbag (if you have one) prior to messing with it.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • lennon
      • Jun 2008
      • 1416
      im not sure what your problem is, but maybe you put a wheel in a different spot than it was before, and it may be your issue. sometimes bends and problem wheels become more obvious when you move them to the front.
      • 36brua
        • 689
        thanks for the responses. . I'm going to remount wheels and have alignment etc.
        • M5wanaB
          • Aug 2007
          • 405
          did you overdue your parking brake adjust and now have a wheel dragging?? just an idea.
          1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
          • 36brua
            • 689
            Maybe. but car was driven from Bay area to Santa Barbara and same steering deal. I thought if I had it too tight the p bark shoes would have.. umm.. 'seated' , burned in, by then ! this is my sons car. he said he didn't smell any thing. but who knows what they may've been doing in the car ! i'm going to check
            Thks
