lock to lock
  • Herb
    • 430
    lock to lock
    If i'm starting with out a motor and doing a s50 swap what streering rack would be better than the oem one? Parts list anyone?
    bmpr stkr: real racers go left and right... so tru
  • Sean
    • 5793
    Addisimo here on the forums used a Z3 2.8i steering rack. He says he loves it quite a bit.
    It's a constant ratio too, doesn't vary.
    That's probably what I will get for my car eventually.
    Edit: sorry had the number of turns wrong. didn't mean to spread mis-information.
    - Sean Hayes
    • Jason89i
      • Sep 2004
      • 875
      Originally posted by Sean
      Addisimo here on the forums used a Z3 2.8i steering rack. it's two full turns, lock to lock..
      wow, thats quick. e30=4 turns lock to lock. e30m3 and e36=3.5 turns lock to lock. e36m3 = 3.0 turns lock to lock. i put in the e36 rack and its plenty quick. are you sure the z3 = 2.0 turns lock to lock? were there any modifications to get it to fit? my e36 rack needed to have spacers on subframe and steering linkage modified (shortened.) cheers, jason
      • Herb
        • 430
        Thank, for the info, I had read somewhere that there was a really quik ratio, but couldn't find the thead again. Mtriple is using a manual rack... any one know abut it? :D
        • James Crivellone
          Head Janitor
          • 6304
          I have an e30 m3 rack in my car and its much better then the stock one.
          • Ryan Stewart
            I Love Miatas
            • 8978
            The Z3 rack is actually 2.7 or 2.8 turns lock to lock and the debate is whether its that much faster or if its just the linear rack with a sucky turning radius.
            I think the 3.0 rack is perfect, if only there was a non-power version available.
            Im now E30less.
            • Herb
              • 430
              What about mtriple's manual rack on (ultimate bmw forum), what's his ratio.
              • Jordan
                • 12913
                He posts here as well, why don't you ask him?
                https://mtechniqueabs.com/
                • DanGillan
                  • Mar 2004
                  • 4061
                  to my knowledge he has a euro manual rack, still 4.4 turns lock to lock, just no power steering.
                  Dan
                  • Jand3rson
                    • 37587
                    This is an upgrade I'd like to do in the near future. Is swapping racks too bad of a job?
                    • Addissimo
                      • Mar 2004
                      • 1820
                      yeah... my rack is just shy of 3 turns to lock... I havent driven with it in yet, but i'm sure it'll be sex. For all of you wanting to do the conversion, I'll hook you up with info so you dont have to pay zionsville for it. I got my rack for $200... and you only need about $15 in hardware to get the knuckle to work. Seems like its probably cheaper than an m3 rack.
                      -Addis
                      Doing something M50 related? -> http://www.addissimo.com
                      On Myspace? ->http://groups.myspace.com/r3vlimited
                      BF2142 SN = BillyGoose
                      • Chris E30 Cab
                        • 866
                        -Addis
                        Where did ya get your Z3 rack for US$200? Used? I hope new and they have another ;)
                        • MattM20
                          • 641
                          i have the z3 rack aswell and have been using it since july. the z3 rack tightens the steering alot, it almost feels like the stock rack without power steering, and it also increases your minimum turning radius. the change in minimum turning radius is a big reason why you cant accurately compare steering racks with lock to lock numbers alone. the z3 rack is somewhere between 2-3 turns lock to lock, however, if it had the same min turning radius as the stock rack it would deffinately be very close or beyond 3 turns lock to lock.
                          • Brew
                            • 3060
                            -Addis
                            I'm interested. PM me or something. Thanks.
                            '91 318is
                            • Ryan Stewart
                              I Love Miatas
                              • 8978
                              -Addis
                              Dittodittodittoditto! Id pay but Zionsville only sells used racks with the kit and youall know me, warranty or bust.
                              Im now E30less.
