hey guys.
Got another few questions for you! I want to make sure everything is 100% taken into consideration till its all set up so few more questions.
one: we all know the difference between the two struts are the tube (vertical) part of it being either 45mm or 51mm. I need to know if there are ANY other differences between them
Particulaily interested in whether the wheels sit any further out in the gaurds between the two (would assume you could tell by measuring the position of the hub in relation to the bottom ball joint?)
two: using M3 cabs, how much further forward to the wheels sit? has anyone actually measured? im sure i would be able to find out the degree increase on the net somewhere (i have done before), but havent seen the change in wheel placment in a straight line forward mentioned anywhere
(i should probably say why i ask... im running slightly oversize tyres, and dont want to remove the plastic plates infront of the wheels the plastic brake air ducts go to if it can help it as they are, more than anything, protecting my two air compressors from getting wet, and so ill have to relocate them if they need to be taken off. i doubt they actually have any worthwhile effect to brake cooling)
three: what would you all recommend for toe settings? I know the theory of what toe does to a car, but havent had the chance to play around with it and see what it does in a real life situation. Should i use the factory recommendations for toe despite the change in both caster and camber up front or..?
thanks!
thanks!
