So I have the following pieces:
Personal Grinta
Personal Horn Button
NRG Momo to Personal/Nardi
Momo E30 Hub Adapter
Love the setup. Want a horn and to finish the install. The momo hub adapter e30 adapter has a black wire with a spade terminal. If you ground that horn goes off. So I know what needs to happen.
Now the pieces I have are the 'ring with spade terminal'. The horn button has a single spade terminals. How do I wire this up to work? Going from hub adapter wire to horn button is no go.
What I believe needs to happen is run the ground to the horn. Then run the horn button to ground? This would interupt the ground and when you press the horn button it completes the ground and fires off the horn? Is this correct?
Personal Grinta
