I just replaced all my suspension and everything is great except for I noticed today that the front pass. side spring makes a popping noise when I turn full right lock. I am guessing that the upper and lower spring perches are not rotating in sync which is causing one end of the spring to rideup past the stopping point on the spring perch, then the spring perch snaps into sync with the other one and the sound I am hearing is the end of the spring popping back into place.
I felt the lower end of the spring and it is right up against the stop on the perch so that is not the issue there. I am guessing that I might have the strut nut too tight or that I just need to jack the car up and let it back down and let something settle.
Do you have any ideas?
