I put my order in for the 4100's with Jack last week. $2300 is hard to beat!
What are coilovers? And are they the best?
Originally posted by 5ickride View PostSo it seems that with a suspension set up, coilovers ARE the way to go.
THanks
I'm trying to live with my Bilsteins, but I may end up getting weak and just buying another set of 4100s. (I've got them on my E46, and had them on my old E36. Of all the suspensions I've owned/used, they are by far my favorites.)2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
Originally posted by Janderson View PostThis is a great thread, lots of good info. I think I might go for that Gaz kit!2006 GMC Sierra 2500HD 4WD LBZ/Allison
I was speaking with Jack about possibly buying the AST's kit being sold over at e30tech and he said I should also buy the other parts that compliment this set up to perform at an optimal level like; control arms, tie rods, bushings, mounts, etc...about another $1k in parts on top of AST's $2300 for the kit. Needless to say, it starts to add up for a seemingly top level suspension upgrade.
I like the fact that you can switch around your springs to your liking/style of driving and also have the ability of height adjustment. Im beginning to know a bit more about coilovers but what i want to know is if you guys that have them feel like its a great improvement over something like billy sports/hr sport set ups? Night and day? Or are coilovers geared more towards track use/auto x?
thanks for all the replies.
The control arms, tie rods, bushings and mounts are basic maintenance that you should be doing as a matter of course. Do them first before you buy any springs/shocks/coilovers. Keeping the suspension consistently pointing in the correct direction and not breaking off is the most important thing you can do to improve handling.
IMHO, the big problem with the spring/shock combos is that the super soft springs tend to bottom out way too easily over bumps. A proper coilover setup allows you to shorten the front strut, allowing more travel, and allows you to install enough spring to cope with the weight of the car. Are H&R Sports w/ Bilsteins a bad setup? No. Could they be improved on A LOT? Yes.
Past a certain point, all suspension mods are geared more for track/autox use. IMHO, the magic of the ASTs is that they give you more without compromising ride quality.2006 GMC Sierra 2500HD 4WD LBZ/Allison
Could you guys give me some opinions on the 400 dollar weld on coils from GC versus their super kit where its a premodified strut housing etc? Are they the same exact thing but they do the welding for you?
I'm going for a street/track setup, and I would like the adjustability that coil overs offer. Care to help a brother out:D
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
Originally posted by phreshkid View PostI too would like to know the answer to this question stated above.
As of now, I am going full GC coilover kit and I'm pulling the trigger within the next three days. How do the two compare against eachother? Or maybe they don't?
The $400 kit is sleeves (sorry, to be clear I mean height adjusters) and springs. You need to do all the work to have the housings modified in order to use this stuff. That's not bad, just saying. Also, the full kit includes camber plates (I think) and other bits that you may or may not need to buy. So the $400 kit is not a direct comparison.
One big difference is the full kit comes with dampers too. Now if you have these then of course you don't need them twice.
To the OP............
I think most of this has been covered....adjustable ride height, ability to change springs, generally can be a much better set up (IE matched dampers/springs), better performance (depending on the kit), stock size spring/damper set ups are an improvement over stock but leave a fair bit to be desired all around.
Ultimately though the "need" for a coilover set up should be based on what you need to get out of it, what your goals are. There are a lot of kits on the market and many are plenty good especially considering what you pay for them. But ultimately you'll need to determine how important overall performance (track/autoX specifically) and street ride quality are to you. This is where differences will start to come through quickly.
Obviously quality is an issue too but assuming you're not getting a complete kit for $500 this shouldn't be a huge issue. ; )
Cheers.
