325ix vs corrado koni's
  • lifeiskaos
    • 1709
    So how come people seem to prefer Corrado front struts, when IX struts are valved for an e30 and the right diameter? Just curious...
    The best reason I've come up with (not from a reliable source) is that the Corrado has an internal spring that prevents the shock from extending all the way. Is that true? Is there another reason?
    Doing my coilover conversion soon and am about to pull the trigger on IX front strut inserts.
  • E30SPDFRK
    • 5709
    Mostly because Bilstein only makes an HD for the IX. And because everyone reads what they see on the forums and do the exact same thing.
    Byron
    Leichtbau
    • 87e30
      • Jul 2008
      • 5676
      What are the differences between the two? Does the IX require you to cut the housing and ad a spacer inside the strut housing as well?
      I just hate everyone.
      No need for discretion.
      • lifeiskaos
        • 1709
        Who said anything about Bilstein's? ;) Koni makes 325ix specific front shocks.
        Yeah, the Corrado and IX struts are exactly the same length, but the IX shocks are made for 51mm strut housings. So yes, spacers underneath the shocks would be used.
        • lifeiskaos
          • 1709
          bump... getting closer to ordering front shocks
          • E30_fiend
            • Apr 2006
            • 7348
            personally Mitch, I would go for the iX inserts if not for price then for simplicity. The corrado struts need be adapted with that expensive glad nut. So if you buy the iX konis, you will probably still be ahead of the corrado price.
            Where are you going to purchase them from? Personally Im just going to run iX bilsteins in modified housing for my car. Same height as the expensive stuff it just doesnt have the dampning. And you will get the same height out of the iX bilstein as you would out of the koni for corrado ot iX.
            Taylor
            • lifeiskaos
              • 1709
              Taylor
              Exactly. I don't know why people use g60 inserts at all... 325ix are the right diameter, same length, and valved for e30's.
              soloperformance.com had a great sale on koni's in June, but I haven't checked current prices..
              Let me know before you start modding your strut housings. I have tools to make it MUCH easier.
              • bear
                • Jun 2010
                • 191
                anyone ever find that great deal on ix struts?
                91 325ic
                85 528e
                92 325i
                86 535i gone
                92 325is gone
                • bear
                  • Jun 2010
                  • 191
                  nevermind, found thmotorsports $160 each for koni sports with free shipping, ftw
                  http://thmotorsports.com/koni/koni_s.../i-105409.aspx
                  91 325ic
                  85 528e
                  92 325i
                  86 535i gone
                  92 325is gone
