drift vs bricks need help
  • bear
    • Jun 2010
    • 191
    okay I bounced my 91 vert off of a brick curb about 1 foot high while drifting around a parking lot, a good laugh on my part, anyway, put on a new control arm, new strut tube and strut, and got the car aligned, but my wheel is still not centered front to back (from sideview)in the wheel well anymore.
    I thought about getting new eye adjusters and replaceing the stock control bushing so I could gain that adjustment, but I would rather know what happened, could my frame tunnel have moved inward some? it still looks the same, ie pushed the control arm bushing mount point inwards. or could my crossmember under the motor, where the ball joint attaches, have moved some.
    I guess I need to know what the weakest point is so I can straighten the frame out rather than just adding more adjusters to the car, thanks for all the wise and wise-ass help in advance
    I guess I should add that only the air dam and front tire hit, it bent the control arm end back about 2" and was still driveable save for a bit of rubbing, I changed the strut and tube set after changing the control arm and bushing still left the wheel un-centered. anyway it was a great 40 mph slide with lotsa smokin rubber wooha
    91 325ic
    85 528e
    92 325i
    86 535i gone
    92 325is gone
  • E30_fiend
    • Apr 2006
    • 7348
    pics or it didnt happen
    • bear
      • Jun 2010
      • 191
      right under the bumper you can see the sheetmetal of the valance is still a bit funky, I didn't get all the tweakage banged back out, and I didn't want to bondo it, so I just bent it back, reshaped it and resprayed it, the airdam I just heatgunned back in to shape, didsome filler and resprayed that, this is all the evidence I have, shoulda took before and afters I guess, but you can see the relationship of the wheel and the fender opening, it sucks, I'm gonna try to fit a bottle jack between the control arm bushins and sprea the rails a bit and see if that produces any change for the better, I do body and paint for the fun of it or lack there of in my garage so those repairs were not too tricky.
      91 325ic
      85 528e
      92 325i
      86 535i gone
      92 325is gone
      • kronus
        • Apr 2008
        • 13032
        Your front frame rails are tweaked, most likely.
        cars beep boop
        • bear
          • Jun 2010
          • 191
          and here is the only 2 of that side I took before the bender. man resizing with photobucket sucks the crap out of the photos!
          91 325ic
          85 528e
          92 325i
          86 535i gone
          92 325is gone
          • bear
            • Jun 2010
            • 191
            frame straightener should be able to fix it right up? maybe they can straighten out my old camber shit too. I've had camber plates on it ever since I bought just to make the camber match, one wheel was straight up and the other very neg.
            91 325ic
            85 528e
            92 325i
            86 535i gone
            92 325is gone
            • bear
              • Jun 2010
              • 191
              dropped crossmember today, has a small tweak in it, compared it to a spare I have and it is way out, so problem solved. btw crossmember is way cheesier than I thought it would be, but i'd rather bend that then the rails
              91 325ic
              85 528e
              92 325i
              86 535i gone
              92 325is gone
              • BimmerScreamer
                • Dec 2008
                • 413
                BMW agrees
                Anything can be done
                • lonestar22
                  • Aug 2005
                  • 417
                  i know this sounds stupid but did u get an alignment after the incident?
                  Originally posted by Lof8
                  Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
                  • bear
                    • Jun 2010
                    • 191
                    yessuh, sho did, was able to adjust the toe and camber, but not wheel placement in the arch, car drove alright, but looked way wrong, also steered alittle too light so the caster musta got jacked too. I just could'nt see the tweak in the crossmember while in the car, and thought it was bent frame rails, actually had to raise camber on one side way more than the other to make it line out, but the bend in the crossmember is pretty obvious next to the new one. once my coilovers come in and my dz's go on I'll put it back on the ground and see how well the new crossmember fixes it.
                    91 325ic
                    85 528e
                    92 325i
                    86 535i gone
                    92 325is gone
