Advise needed.
  • brandonj1
    • 318
    Advise needed.
    I am currently running the eibach pro kit in my car, with billy sports. They were in the car when i bought it. i dont know how many miles are on them. it cant be that many becase they are relatively clean, a light swipe of the finger mad them look new. should i:
    A) run GC sleeves on them -> 400 bucks
    B) Complete GC kit -> 1300 ish
    C) rebuild then gc sleeves -> i dont even know + 400
    D) hr race springs -> 300 or so?
    C)new billys sports then add the sleves later on 900+- and over time?
    I want low and a little bit of forward rake. would like it to be about equally stiff if not a tad tighter and run 16x8 -10 offset with only a minor fender pull in the front, hopefully none in the rear.
    I have a early IS
    thanks in advance.
  • Philo
    Ich esse kleine Kinder
    • 3334
    1) Learn to spell Advice.
    -tim
    Originally posted by Jordan
    I like the stance
    • caliGreen
      • 195
      now thats really no help
      • dvck
        • Nov 2009
        • 3394
        Advise:
        [Verv]
        Offer suggestions about the best course of action to someone.
        Advice
        [noun]
        Guidance or recommendations concerning prudent or future action,
        typically given by someone regarded as knowledgeable or authorative.
        Just sayin'
        to answer the OP...
        how is the ride now?
        • Philo
          • 3334
          If money is not an object, just buy the whole GC kit and be done with it. What's your specific reason for wanting something other than what you have on the car right now? Stiffer rates, lower?
          -tim
          I like the stance
          • brandonj1
            • 318
            want it to be about an 3/4 an inch lower inthe front. And a half in the rear and want it a bit tighter
            • brandonj1
              • 318
              [QUOTE=mr.dvck;2067829
              to answer the OP...
              how is the ride now?[/QUOTE]
              it's low and moderately stiff I want lower and stiffer
              • dvck
                • Nov 2009
                • 3394
                agreeing with Philo here, if money isnt an issue, which seems not to be, just go with the full
                coil system, much more versatility on both height and stiffness.
                • brandonj1
                  • 318
                  Well money kinda iss but, Would it be just ass stiff as if I my billys and did the sleves over the koni in the gC
                  thanks
                  • bear
                    • Jun 2010
                    • 191
                    keep your billy's put the gc coil kit with 6-700ish springs in back, and 450-500 springs in front, you can choose spring rates when you order, $400 and your done
                    91 325ic
                    85 528e
                    92 325i
                    86 535i gone
                    92 325is gone
                    • brandonj1
                      • 318
                      thank you that's what I was hink but I didn't know what to expect as far life on the billys. Thanks. Next pay check!
                      • j0oftheworld
                        • 480
                        You've got to modify your struts to run Coil overs..
