Poly sway bar bushings for 21mm and 14.5mm bars
    Who sells them besides bmpdesign?
    89 325is track project / 05 x5 / 99 M3
    E30 stuff for sale | Parts I'm looking for
    try searching on bavauto under a cabrio for the front bar then under an m3 for the rear bar
      Bummer...I just checked and they don't appear to have anything.
        what about Turnermotorsport.com??
          Negative.
            shitty. I will do some digging when I get home and see what i can find
              Thanks....
                Bump......
                  I modded my subframe to use Energy bushings, so I can get whatever size I want, cheap.
                  Closing SOON!
                  Thanks for 10 years of fun!
                    Hmm. Got any details on how you did it?
                      I just bought 22 and 15mm busings from Powerflex. I'm hoping they fit, I'll try to get them on tomorrow and pst up the results.
                        Had plates welded on the subframe that go from the original (broken) mount tab (the "hinge" or whatever) to the rear subframe bolt, so you have to find longer bolts.
                        I have not installed it yet. I expect some hassle in doing so, but when the motor is out from the swap, on it goes.
                        Closing SOON!
