Cabrio rear suspension SQUEAK and clunk
  • mrl325i
    • Oct 2006
    • 170
    Hello. I thought my shock mounts were shot so I replaced them and the rear shocks, too. I have a squeak coming from the pass side rear over bumps along with a thump/rattle that happens when I run over a series of small bumps (like a wsshboard surface). I cannot see what is worn out under there. Anyone have an idea what the likely culprits are, and what I should be looking for? Thanks.
    Mark
    88 325ic
    03 325i
  • mrl325i
    • Oct 2006
    • 170
    Nobody wants to help. eh?
    Mark
    88 325ic
    03 325i
    • E30_fiend
      • Apr 2006
      • 7348
      take a look at your front upper strut mounts. If they are cracked or uneven then replace them. sometimes the mounts will blow but keep the shock in place. they will get stuck in a pushed up position. Its kind of hard to explain. check them out, it sounds like your problem. could also very well be your control arm bushings
      Taylor
      • thereisnoyun
        • Feb 2007
        • 2301
        squeeking in the rear is something I fix just now. REAR subframe bushing. All noise gone. Also replace the swaybar bushing as well, as that can cause other squeeking issues, but the main squeek is from subframe bushing.
        • mrl325i
          • Oct 2006
          • 170
          Found the clunk -- worn out u-joint. Had them replaced and the driveshaft balanced and all is good.
          Still trying to figure out the squeak, though. The bushings back there look pretty good.
          Mark
          88 325ic
          03 325i
          • mrl325i
            • Oct 2006
            • 170
            Originally posted by thereisnoyun
            REAR subframe bushing..
            I think I know where that one is, but can you confirm? Have a pic? Thanks.
            Mark
            88 325ic
            03 325i
