Hey Everyone,
So I bought my first E30 a few weeks ago. I'm now working on the steering return problem. I've done some research and want to narrow it down.
Symptoms/stuff:
From my research Ive found possible causes are:
Toe in incorrect- Please look at toe specs and tell me if they would be the cause.
Washers between strut and hat missing- Can someone give me instructions for checking this?
Steering rack is shot- Again, instructions on how to test for this? Drive w/o belt??
Steering rack u-joint is toast - how to test?
Thanks in advance, Jeff
Symptoms/stuff:
- Power Steering is light and feels like a normal car
- Returns nearly to center, only 90-45 degrees from center
- PO had it aligned. total toe .32 degrees (.16 on each side)
- PO replaced control arms/struts before alignment
