The suspension setup/ride height thread
  • jaywood
    • Jul 2010
    • 4528
    #301
    Originally posted by simplyclean325i
    also, what's the best suspension set up for stance? i hear a lot of good things about kw's. basically a coil over that will allow me to drop it as low as i want and good camber kit. thanks.
    Your BC's aren't low enough for you?
    • ak-
      • 12422
      #302
      Yea, how far are you down in that picture?
      1991 325iS turbo
      • jaywood
        • Jul 2010
        • 4528
        #303
        I bet he's all the way down.
        Simplyclean, if it is all the way down and it's not low enough for you...you can get smaller springs to help drop it some more. Also, you can take out the spring pads if you haven't already.
        • simplyclean325i
          • Apr 2011
          • 259
          #304
          previous owner said the back is dropped all the way and the front can go a little lower. i would like to go lower but my front lip is an inch off the ground and oil pan sits real low. ride is actually really nice and it's at it's stiffest setting.
          • graffeedy5
            • 106
            #305
            with billstein sport shocks and struts and h&r sport springs how low will I be? Will I have any trouble fitting 15x7 or 15x8 maybe staggered?
            • Blackout
              • Apr 2011
              • 4130
              #306
              It will drop around 1.3 inches Front and Rear.
              Lame drop, IMO. Go with race.
              You wont have any problem fitting those wheels, under either case.
              » PARTS FOR SALE
              » TRANSACTION FEEDBACK
              • grippymonkey
                • Jun 2011
                • 759
                #307
                My two previous E30's. I'll have another update soon for my new project 318is.
                1986 325
                Intrax springs
                stock pads
                stock shocks
                stock sways
                195/60/14 Falken 512's
                ^ These are the only pics I ever had of the car. The pics from the passenger side makes the car look a little higher than it is because of the angle of the hill. These springs actually got the car quite low. The drivers side was pretty close to what it typically looked like. It was enough to scrape the header over any normal sized speedbump.
                1990 325i Vert
                Vogtland sport springs
                Bilstein sports
                stock pads
                stocks sways
                205/50/15 Dunlop DZ101
                15x8 +20 Rota Slipstreams
                ^This was a really good drop for the rear of the car but not for the front. If I still had the car I would've taken the front pads out and used some sort of drophat to get rid of the rake. The car handled pretty nicely with this setup, and it was very comfortable for a daily.
                GRIPPY'S*GARAGE
                • farrk007
                  • 11
                  #308
                  I have to ask folks here that are experts as i am not that familiar with E30 suspension set-ups.
                  What combo is the "semi-coilover"? My loose interpretation is that you have the set-up in the front with regular lowering springs in the back....cos so far that set-up seems to look the sweetest from what i've seen so far.
                  Thanks.
                  • grippymonkey
                    • Jun 2011
                    • 759
                    #309
                    ^ I would consider a semi/coilover a sleeve coilover kit like Ground Control front and rear with some kind of upgraded shock like bilstein or koni to match. A full coilover suspension is typically a kit that has the damper or shock body threaded for height adjustability. There is usually no modifications needed and it is all complete/sold as one item.
                    A "semi-coilover" wouldn't be a coilover in front and spring in back. It would be really hard to even buy that setup because most companies don't sell just front or rears. You would have to piece it together from used parts. It also wouldn't be matched very well since most spring kits are softer than most coilover kits.
                    GRIPPY'S*GARAGE
                    • Holland
                      • Nov 2008
                      • 7202
                      #310
                      Suspension:
                      BC Coilovers
                      Fender heights:
                      22 front
                      22 1/2 rear (needs lower)
                      Wheels:
                      EMS 16x9 10 offset
                      Tires:
                      Falken Azensis 205/40/16
                      Everything is wrong with this car but everything is so good too.
                      Originally posted by DEV0 E30
                      • Wh33lhop
                        • 11705
                        #311
                        I concur.
                        paint sucks
                        • mo diesil
                          • Jan 2011
                          • 275
                          #312
                          coils i made only 1/4 way down
                          • Shwane30mazhaR
                            • Jun 2011
                            • 44
                            #313
                            whats wrong with his setup? just out of curiosity cuz im going with the same thing once i start working on suspension
                            *Drive to Live*
                            *Live to Drive*
                            TM
                            • CHIF8008
                              • 3447
                              #314
                              they dont like the euro plate, french fogs, volvo lip or the rack
                              -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                              -The Beauty in the Tragedy-
                              MECHANIC SMASH!!- (you all know you do it)
                              Got Drop?? ;-)
                              But of course
                              E30s are know to be notoriously really really really ridiculously good looking
                              • Shwane30mazhaR
                                • Jun 2011
                                • 44
                                #315
                                haha. ok nevermind then.
                                *Drive to Live*
                                *Live to Drive*
                                TM
