The suspension setup/ride height thread
  • bmwm3n528
    • 3654
    #31
    Originally posted by ed94r
    IE Stage 3 Springs
    OTS Bilstein Sports/Boots
    10mm rear pads
    3mm front pads
    IE Street Adjustable camber plates
    E30 M3 CAB's
    Ground Control RSM's
    Stock bars
    Eibach Front Strut Tower connector
    Ronal LS's (the old ones)
    Yok ES100's 225-50-15. And no rubbing!
    Suspension Techniques Bars/reinforcements to follow...
    Ed
    Dude that car looks fantastic!
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    • e9nine
      • 1890
      #32
      1991 318iS
      Koni SAs
      Ground Control Semi Coilovers
      Ground Control Adj. Camber plates
      15 x 7 BBS RZ wheels
      205-55-15 Kumho ASX
      1988 325
      Koni SAs
      205-55-15 Yokohama AVS ES 100
      1986 325
      Koni SAs
      Ground Control Adj. Camber Plates
      15 x 7 Kosei K1s
      225-50-15 Falken Ziex 512
      1991 318iS
      Bilstein Sports
      15 x 7 Kosei K1s
      1991 318iS
      Koni SAs
      17 x8 / 17 x 9 BMW Style 32 wheels
      215-40-17 Wheels (name is not important in this case)
      1991 318iS
      Koni SAs
      17 x8 / 17 x 9 BMW Style 5 wheels
      • rs4pro3
        • 5808
        #33
        1985 325e
        Racing Dynamic green springs
        Bilstein Sports
        No spring pads front or rear
        21mm front and 14.5mm rear bar
        Turner rear shock mounts
        Front and rear strut tower braces
        All Urethane rear end bushings
        Fully adjustable sway bar links with m3 style front link
        85 325e 2.7 ITB'd stroker
        • bmwm3n528
          • 3654
          #34
          1989 325is
          H&R Sport
          Bilstein Sport
          JT Designs RSMs
          New OE Rear subframe bushings
          16x7" BBS RX
          205/50 BFGoodrich gForce Sport
          Trevor Ely
          • rs4pro3
            • 5808
            #35
            New setup
            Custom semi coilovers
            350lf/450lb
            Ireland Race camber plates
            Sparco front bar
            Lukas rear bar
            Turner RSM
            Bilstein sports
            21mm front 19mm rear sway bar with adjustable links
            bolt in roll bar
            -2.25 front camber
            -2.5 rear camber
            • Low Level E30
              • 1646
              #36
              Let's see some more here --- maybe some more early cars? H&R Sports, anyone?
              • PiercedE30
                • Apr 2005
                • 4220
                #37
                H&R Race Springs all the way around
                Koni Yellows
                Vorshlagg/MotorForce Adjustable Camber/Catsor Plates
                Powerflex Rear Subframe Bushings
                IE Trailing Arm Bushings
                IE Rear Shock Mounts
                IE SS Braided Brake Lines
                25mm ATE Master Cylinder
                Here are some pics:
                It'll look lower once I get the M-Tech II door panels and sideskirts put on.
                Almost forgot: stock bottlecaps with 195/60/14 Bridgestone Turenzo's (sp?).
                My 2.9L Build!
                • bmws50b30
                  • Aug 2005
                  • 1151
                  #38
                  Turner J stock spings with matching bilsteins (revalved)
                  ST sway bars
                  THR CAB
                  Earl's SS brake lines
                  IE Green Subframe poly bushings
                  JTD RSM
                  Sparco strut bar
                  Stock spring pads
                  1991 330is
                  • bmwm3n528
                    • 3654
                    #39
                    ST sway bars
                    THR CAB
                    JTD RSM
                    Sparco strut bar
                    Stock spring pads
                    That's perfect(If we're judging by 'looks'). For some reason I don't remember J-Stocks being quite that low.
                    Trevor Ely
                    • Garageaholic
                      Freestyle Fabricator
                      • Dec 2005
                      • 5204
                      #40
                      HR sports with bilstein sports
                      M30 in it with an extra 80lbs in front end.
                      Running 17x8 on 215/40 17 tires
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      Instagram.com/garageaholic
                      Youtube.com/garageaholic
                      • MikesJo
                        • Mar 2004
                        • 989
                        #41
                        H&R Race w/ Bilstein Sports on a 318is.
                        Vancouver Portrait Photographer
                        E30 M3 Wallpapers
                        • sticksdaman
                          • Apr 2005
                          • 2987
                          #42
                          vogtland springs
                          KYB shocks
                          195 60 14 in the front
                          195 60 14 in the rear
                          *update*
                          new set up
                          205 50 15 all around on 15x7 wheels
                          one spring pad removed from the rears
                          Originally posted by ebelements
                          Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                          • japspecvr6
                            • Apr 2005
                            • 602
                            #43
                            Originally posted by sticksdaman
                            vogtland springs
                            KYB shocks
                            .....not bad at all......:up:
                            M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                            • Lof8
                              • Oct 2006
                              • 2827
                              #44
                              spring pads
                              After looking through this thread, I see some people are running thinner spring pads or none at all. Where do you get the smaller spring pads? Does going with no spring pads create squeaks? Any drawbacks to no spring pads? It seems like a good method to fine tune the ride height.
                              thanks, Andy
                              S50'd
                              Originally posted by TDE30
                              What is this faggy shit I have happened upon?
                              I can always live in a M3. Can't M3 a house.
                              • craz azn
                                • 743
                                #45
                                1988 325iS
                                H&R Sports (blue front, red rear)
                                Bilstein Sports
                                one dot spring pads front and rear
                                stock iS 20mm front sway bar w/ M3 strut tabs
                                stock iS (12mm??IIRC) rear bar
                                195/60R14 tires
                                Rippin' Proper | Youtube | Vimeo |
