powersteering question
  • JT325is
    • Oct 2009
    • 1242
    my powersteering went out last night, and i now hear a clicking noise as i turn the wheel, and definitely much harder to steer. i have a 91 318i and its my first M42. could it just need fluid? belt? is there a powersteering reservoir? i cant find it for the life of me. any input is appreciated! thanks
  • mikes325is
    • Jan 2010
    • 32
    The reservoir is right behind the air filter box the reservoir is brown
    • güber325
      • Jan 2010
      • 18
      and it says "ZF" on it too.
      shouldnt be hard to find.
      • JT325is
        • Oct 2009
        • 1242
        thank you. i checked my fluid and it seems to be okay... i just dont know why my steering is stiff and why there is a clicking noise..
        • JT325is
          • Oct 2009
          • 1242
          could this be a driveshaft problem? i hear the clicking noise right behind the steering column. u-joint possibly?
          • SpecM
            • Oct 2005
            • 4531
            yea, possably. But whatever you do, keep asking questons here instead of looking under the hood of your own car
            1989 cirrisblau-metallic 325i
            • gearheadE30
              • Jun 2007
              • 3734
              look at the belt. If it is there and not frayed, it's fine for now. The pump could be shot if the fluid is really really old or maybe just some fluke thing. I can't explain the clicking without more info, but collapsed upper strut bearings can do that and make the steering stiff.
              Project M42 Turbo
              • shawn55
                • 5
                I think its mostly the driveshaft problem.But i cant understand why there is a clicking noise.Just check it.
                BMW Angle Eye Headlights
                • TwoJ's
                  • Oct 2005
                  • 4908
                  Does it "whine" when you turn the wheel? Have you looked to be sure that the belt is there and on the pulley properly?
                  • IronmanE30
                    • Sep 2009
                    • 2121
                    Like other suggested check your drive belt for the power steering pump is in good condition. If the clicking nose gets faster when you accelerate, check you guibo, a rubber damper at the rear of your transmission and on the front of your drive-shaft.
                    • JT325is
                      • Oct 2009
                      • 1242
                      Thanks for all the input you have all been very helpful. There is no whining noise just a lot of clicking while steering.
                      • iwantspeed
                        • 3164
                        I can come help you diagnose this
                        ygpm
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
