Ran into a little problem with g/c coils
  • Schwarz325
    • Aug 2009
    • 487
    alright so, tonight i was mocking up my coilovers to see if i need to cut any of the strut housing out and i ran into a little problem. From what i understand the threaded collar is suppose to go over the strut body and stay there once you tighten the allen wrench. My problem was that the collar wasn't going over the nut that holds the strut in.
    I'm running tokico blues with supplied retainer nuts to hold the strut in the body.
    I took a pic of a basic setup with all the components there.
    stock fitment
    Just a little overhang
    What i'm i doing wrong? how to fix this? maybe i'm just too tired from working all day and should worry about this tomorrow.
  • kishg
    • Sep 2006
    • 2624
    did GC say that setup would work? i think they are designed to be used with Koni.
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
    • Schwarz325
      • Aug 2009
      • 487
      Yes, i talked to them about it.
      • Wishno87
        • 6025
        You need to weld on your perch first.
        Then put the threaded sleeve and adjuster on it.
        Then put the shock in.
        If they came with instructions you should read them because you have it all wrong.
        • Schwarz325
          • Aug 2009
          • 487
          I know all that, the nut that holds the shock down is the issue, the threaded sleeve has to be under it and it leave the gap between the spring and the perch that g/c supplies
          • livetheride
            • 444
            sleeve goes on first...
            • Schwarz325
              • Aug 2009
              • 487
              yes, but the top of the sleeve hits the bottom of the nut and creates a gap between the strut mount and the spring perch that g/c sends you.
              I may not be expressing my self right
              • Schwarz325
                • Aug 2009
                • 487
                i think i got it figured out, since the top of the sleeve hits that nut, i'm gonna weld the d collar just right so that went the shock is tightened down it'll hold the threaded sleve in place. Or at least that's the plan, we'lls ee how it goes. Thanks
                • Hellabad
                  • 807
                  Call me, you can't do it that way. The GC kit must be installed and welded with no strut insert in the housing, therefore no gland nut would be in the way. (that big nut at the top of the strut housing is called the gland nut)
                  The reason you need to weld the ring exactly where the directions say, is that allows for future modifications. If you weld it as you have described, you will be backed into a corner, and may have to redo things in the future.
                  It is easier than it looks. call me at 530 677 8600
                  Jay
                  Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                  Ground Control Gallery
                  The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                  • Schwarz325
                    • Aug 2009
                    • 487
                    I'm not welding it with the strut in the housing haha.
                    I'll call you tomorrow
                    • Stephen
                      Шлем ишака
                      • 10774
                      What short tokicos are you using? I want a review once its assembled properly
                      • Schwarz325
                        • Aug 2009
                        • 487
                        They're not short, they're the shitty blue ones.
                        Oh btw, me and jay resolved this, i just didn't express myself right.
                        Thanks again Jay!
