Rear shock top mounts, need picture
  • izthistaken
    • Jun 2010
    • 387
    I installed new top shock mounts in the rear and I have a bad clunk still because the top 'hat' is hitting the bottom one. When I took them apart the first time they did not look like they were put together properly. Well being an E30 newb I just went along with it and said, well it must be right. Well, there is no way it is right. Can someone please get me pictures to exactly what I need for top mounts and how it goes together? This is ridiculous. :roll:
    Thanks, :???:
    Matt
    -Matt
    http://www.facebook.com/MatthewTrombleyPhotography
    1990 325i
    1999 FRC
    Flickr
  • MattM
    • Apr 2009
    • 931
    does this help?
    Full Build Thread Here
    • Maddog
      • Dec 2006
      • 116
      http://www.pelicanparts.com/bmw/tech...ock-Mounts.htm
      Pelican provides decent instructions on mount replacement. Make sure you put the washers in the correct direction; note photo figure 5, as well as MattM's diagram. Failure to install it correctly will cause premature failure.
      • izthistaken
        • Jun 2010
        • 387
        Thanks a ton guys! I knew it was horrible wrong when I put it back together and this just proves I'm right. Now to find out where I can get the parts asap haha. Thanks again!!!!
        -Matt
        1990 325i
        1999 FRC
        Flickr
