My friend just bought a 89 325i and he plans to go with ground controls coilover conversion kit. He spoke with someone from gc and he was told that if he were to lower his car any more than 1 1/2 inches that he would be riding on the internal bump stops on the bilstein sports. Can anyone confirm this because it kinda seems like bs. Any help would be appreciated. Thanks
Bilstein Sport Question
...not BS. When billys are used on lowered platforms there is very little available bump travel. -
The alternative is to remove the sleeve and shorten the bump stop BUT Bilstein will not warranty self modified units.Comment
1990 Alpinweiss 325i - secret 500whp buildOriginally posted by audiquattrotbimmers b4 b*tches....remember that.
2000 Audi S4 B5 Laser Red
1990 Nissan 240sx - Drift Missile
2006 CBR600RR
The basic slider off the bottom, you might need a drift punch and hammer to force the external yellow tube off the valve body then it's very simple.Comment
2006 CBR600RR
Only if you go nuts on it. The shiny part that you see on Bilstein's are actually the valve body not the piston. Some one else might have another method of removing the tube.Comment
I have to imagine that the "internal" bump stop is present for protection. If you remove or shorten that and get into a situation where you bottom hard what are the ramifications?Comment
Yes but it why? The stops compress some and why do so as they get older They are just hard rubber.
Many here have cut their bump stops shorter. It was fairly common practice 5-6 years ago when everyone was scrapping.Comment
2006 CBR600RR
Or you can have bilstein re-valve the shocks and shorten the bumpstops ;) Or even shorten the shocks.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
