Coilover kit with Bilsteins or Full Ground control setup?
  • F34R
    sLaughter
    • 12376
    Originally posted by LivingLegend06
    Hds are meant for stock height springs, they will bottom excessively when you lower your car. Bilstein sports are meant for lowered cars but some people running coilovers are still having issues with them bottoming out.
    I am tucking 195/55 R14 with Bilstein Sports. And I have yet to bottom out, then again I asked GC for the stiffest rates they offer.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • MC Hammered
      • Jul 2008
      • 2076
      Originally posted by nrubenstein
      Bottoming out the shock and slamming your skidplate into the ground are two different things. With 2" of clearance, nothign is going to stop you from grounding the skidplate, but stiffer springs would help.
      You are right.
      After going on a drive to test out the suspension going over various road conditions and dips at 40-60mph the suspension soaked them all up.
      The issue I have is with ground clearance as going down a crappy alley made the skidplate kiss the ground.
      My 1989 e30 s52 Touring... this is Betty
      My 1989 325i vert (sold)...this is Nina
      My 1991 M5 (sold)... this is Veronica
      Photo comparison: OEM vs aftermarket windscreen for a convertible
      • UDelaware30
        • Dec 2009
        • 336
        FWIW im running the GC coilover conversion kit with 450lb front and 650lb rear. Using bilstein sports and tucking rear and a little front. Never bottom out unless I slam a pothole on these shitty roads.
        I would rather have their full setup but i already had the shocks and did it for pretty cheap.
        • Dude
          • 1119
          What all did you need to buy/fab besides the shocks and the conversion kit
          • Hodge
            • Jun 2008
            • 424
            I ordered from Bimmerworld and talked to them about what I needed. They told me not to overspring the shocks, since they were not custom valved Bilsteins.
            They recommended the 350/475 setup, and it has been perfect. If I go all the way down on the front, it does bottom out though.
            E30- 1989 325is
            • Killacortes
              • 1937
              so my tires on when i got the rims were 205 40 16....
              which would be better 215 45 16 all around?
              i like thicker tires and saw a few people running 225 50 16 in the rear and 215 45 16 in the front.
              r3v does not fuck around. First you get banned, then they shoot you
              • MC Hammered
                • Jul 2008
                • 2076
                Your wheel width and offset will help determine what you can run for a tire.
                • Killacortes
                  • 1937
                  runnin 16x8 et0
                  i know et0 is a horrible idea and stick out a little but i have fender roller on standby
                  • Bimmerman325i
                    • 6854
                    runnin 16x8 et0
                    ask this question in the wheel fitment thread.
                    Save up longer and get the full coilover suspension. You'll be happier that you did, since it includes everything you need and since you are essentially starting from scratch any way you go. Patience is key.
                    2017 Chevrolet SS, 6MT
                    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                    98 M3/4/5 (stock)
