I'm trying to adjust the front toe, but the adjustment piece will not budge. Do I have to remove the outer tie rod from the hub to adjust?
front toe adjustment?
No.
It is pinch fit type of deal, so use penetrating oil for a day or so. It helps if you just get the car off the ground to get some force on it. Also, be careful, a tiny adjustment on the tie rod is a HUGE change in the wheel toe in.
Jay from GCHere is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
Ground Control Gallery
The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
The inner part of the tie rod turns for adjustment once the clamp is loosened. If it doesn't want to turn there is probably corrosion in the threads. PBlaster or Kroil and time for it to work (hours to days, not minutes) should help. In a worst case heat may be required.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
You can adjust these while the cars on the ground?
John F. Kennedy
