Fuck balls!
JOM Coilovers.
hey man I used a 4 inch spring in the rear at 600lbs, I can almost tuck rim on a 14 with no adjusters, pads at all, and get get high enough with the adjuster and 2 spring pad to get like 2inch or more wheel gap. it eliminated the bouciness from the set up because the rear spring is so light. I think its like 220 or something. sense the e30 uses a semi trailing arm it needs a higher spring rate.Comment
