The previous owner of my E30 didn't put power steering fluid in the E30 and drove it around for a month and a half with no fluid. So as you might suspect, steering is quite um.. annoying. I can put the fluid back and it'll be back to normal right?...right?
power steering fluid and shit.
Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Tags: None -
If the system doesn't have fluid in it you can bet on there being a leak. If you are exceptionally luck the leak will be just from a hose, but the odds are that the leak is from the rack and replacement is required. And since the pump has been run dry for quite a while you'll probably have to replace it also.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
If the system doesn't have fluid in it you can bet on there being a leak. If you are exceptionally luck the leak will be just from a hose, but the odds are that the leak is from the rack and replacement is required. And since the pump has been run dry for quite a while you'll probably have to replace it also.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
yep I finally put fluid in there. Worked for a little bit. Then it started making a really annoying sound, followed by leaking. hopefully the sounds stops.
I'm ok with not having power steering, but I'd be happier if I had it. But I'm not going to pay big bucks to fix it, Unless there is a cheaper solution than replacing the rack and pump.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
