Common?
  • E30SPDFRK
    • 5713
    Common?
    Been hearing a clicking from my wheel well so I pulled the wheel to check it out. I've never seen this happen before, is it a common issue with e30's? The bracket really isn't that rusty.
    I'm thinking it's because I'm so low with stock links. I'm going to switch to M3 links when I shorten the struts some more.
    Byron
    Leichtbau
    I'd say that isn't a common problem. At least I've not seen it before.
    • M-technik-3
      • 18946
      you are drastically low so that was bound to happen. inverted arms will cause binding then something has to give. This was common in A1 chassis VW's back in the day.
