I've been fighting these symptoms for a while in my convertible and I haven't found anything that I thought could be the cause. Basically the car drives like it's 'nervous'; it doesn't like to return fully to straight after turning, there seems to be an horrendous amount of bumpsteer, and it just seems twitchy and impossible to drive with any sort of confidence or sense of relaxation. Driving in a straight line requires lots correction and it doesn't stay on the straight and narrow easily. Driving it hard scares the shit out of me because it's unpredictable, twitchy and quirky.
Some points on the car (all parts have roughly 10K mi on them):
H&R Convertible springs (lowered about 1.5" all around)
21mm/15mm OEM bars with urethane bushings
Bilstien shocks
Kmac camber/castor adjustable strut mounts
IE adjustable RTA bolts w/ OEM bushings
All news bushings, balljoints, CAs, M3 CABs, RTABS, subframe bushings, every single suspension piece replaced with OEM rubber.
Full 4-wheel alignment done only 3K ago
e36 steering rack
strut tower brace + lower x-brace
I fee like I've looked at all the likely culprits (CABs, ball joints, TABs, subframe bushings, etc) and everything seems to be in perfectly good condition (it should be after only 10K). I'm really at a loss here, anyone have some ideas? I know it's a convertible and the chassis is obviously less stiff than a coupe/sedan, but this feels more suspension related. Thanks in advance.
Bilstien shocks
e36 steering rack
