Car pulling left and right
  • cganne
    • Jan 2010
    • 103
    Replaced all control arms, tie rods, springs, struts and bushings. When driving if I do a U-turn to the left the car then pulls to left as I drive, if I follow with a U-turn to right...car pulls to right. Took car in for alignment and told them this along with some sort of clunking when turning wheels at low mph or while parking. Told me everything was tight, fixed "alignment" and told me to go to a frame shop followed up with a tire shop cause my tires are bad...they might have 2,000 on them so I'm confident that's not it especially since it pulls both ways periodically. Suggestions?
  • ///digitalme
    • Dec 2009
    • 2088
    thats usually related to steering rack problems, and aligment i have a similar problem...mine is due to bad tierods...check your power steering reservoir....and be sure its properly aligned...i had another e30 with front end damage it didnt pull to the sides so i doubt that is the problem
    • KenC
      King of Kegstands
      • 14396
      You forgot the fat washer that goes between the springhat and the the strutmount.
      Originally posted by Gruelius
      • DÌEGØ
        • 690
        that or the upper strut mounts (aka bearings) are bad. its called memory-steer. the bearings are binding.....and thats where your noise comes from at low speeds.
        Driving:1990 325iS, 2007 335i :devil:
        past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
          I agree with the above. The most likely cause of this is binding at the upper strut mounts. That could be as a result of old and worn out mounts (did you replace them), or improper assembly of the strut/mount. A binding steering rack is a possibility, but it would have been doing this before the front suspension refresh if the rack were to be the cause.
          • cganne
            • Jan 2010
            • 103
            The upper mounts are GC Hybrid Camber Plates, these are brand new as well.
            • cganne
              • Jan 2010
              • 103
              I will not rule out improper assembly, not sure how to troubleshoot this though?
              • KenC
                King of Kegstands
                • 14396
                Then they're probably binding on the springhats.
                • cganne
                  • Jan 2010
                  • 103
                  Can this be corrected, how?
                  • KenC
                    King of Kegstands
                    • 14396
                    There's a washer that goes between them.
                    • cganne
                      • Jan 2010
                      • 103
                      This is what I have:
                      The spring hat and camber plate are one unit fit together with a poly bushing, are you saying that there is a washer that fits on the strut shaft prior to putting this assembly on?
                      • KenC
                        King of Kegstands
                        • 14396
                        So you're running the GC springs as well?
                        Jack the front of the car of of the ground and turn the wheels lock to lock and see if you can feel resistance.
                        • KenC
                          King of Kegstands
                          • 14396
                          There's binding that is preventing your rack from returning to center.
                          • cganne
                            • Jan 2010
                            • 103
                            [quote=KenC;2305219]So you're running the GC springs as well?quote]
                            No, running KW springs/shocks.
                            • cganne
                              • Jan 2010
                              • 103
                              Washer and dust cap were not in...solved binding problem but still having an issue with the "memory steer", any other suggestions? This was not an issue prior to doing the suspension refresh.
