steering rack spacers
  • acolella76
    • 2950
    What size spacers do I need to use for the steering knuckle and for the subframe for swapping in an E36 rack? Would rather spend $4 at a hardware store than $30 at AKG or zionsville...
    -Alex
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    Stack up some washers between the rack and the subframe, that's the cheapest way I think. I'm not sure on the link though due to having an airbag car.
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • george graves
      • 19998
      I'd rater spend $10 from someone on the forum. Anyone make these?
      Originally posted by Matt-B
      • bzboardz
        • 1096
        I picked up a 1/2 bolt spacer from hardware store and was a perfect fit. or try mcmaster.com
        • acolella76
          • 2950
          so i'm guessing you guys would advise against using nylon bushes as spacers for the knuckle?
          -Alex
          • 87e30
            • Jul 2008
            • 5676
            Personally, I went to the store bought a bunch of washers came home and slipped them in until it fit properly.
            I just hate everyone.
            No need for discretion.
            • acolella76
              • 2950
              i mean on the steering knuckle, not between the rack and subframe... i figured since it's already got the rubber guibo on it, using nylon spacers wouldn't be too bad. But i'll stack some washers too
              -Alex
              • 87e30
                • Jul 2008
                • 5676
                Ah okay. Yeah I just used washers there too. I know there are lots of ways to do it, but works for me.
                The rubber stays there so I'm not worried about excess vibrations or anything. Just use some loctite and should be fine with washers.
                • acolella76
                  • 2950
                  how many washers did you use? Im gonna try and use like 5 or 6 on each side of the knuckle, but idk how many to use for the subframe.
                  -Alex
