IE hollow 25mm vs uuc swayBarbarian 22mm
  • Bothfeetin
    • Dec 2010
    • 340
    i was wondering since the IE 25mm is hollow if it will still be as stable at the swayBarbarian by uuc which is a 22mm
    #Treadlifematters
  • KenC
    King of Kegstands
    • 14396
    Stable?
    Originally posted by Gruelius
    • Bothfeetin
      • Dec 2010
      • 340
      i ment as stiff as in which is a better performance wise
      #Treadlifematters
      • blueapplesoda
        • Dec 2005
        • 1904
        are you on race suspension and slicks? if not then get the 22...
        • Bothfeetin
          • Dec 2010
          • 340
          so the 25 is for a full blown race car but since its hollow would it tend to bend more therefor create more sway
          #Treadlifematters
          • Teaguer
            • Sep 2004
            • 6167
            Originally posted by KenC
            Stable?
            Yeah you know for doing kegstands and shit on.
            • Bothfeetin
              • Dec 2010
              • 340
              you never know.......
              #Treadlifematters
              • bzboardz
                • 1096
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  Hollow bars are stiffer. Do your hw.
                  • JeffRR
                    • 277
                    Assuming the drop link mount is in the same position between the 2 suppliers the hollow IE 25mm bar will be approx %150 stiffer than a solid 22mm bar.
                    Stability is all about balance. You can get there with either bar, just depends on the rest of the set-up.
                    • Bothfeetin
                      • Dec 2010
                      • 340
                      ok then but then comes the bushing deal from what i herd the IE bushing are the best any input on the uuc ones
                      #Treadlifematters
                      • KenC
                        King of Kegstands
                        • 14396
                        Originally posted by teaguer
                        yeah you know for doing kegstands and shit on.
                        8)
                        • Hellabad
                          • 807
                          Not necessarily, at all.
                          A 25mm hollow bar (probably 25.4mm actually) will need to be pretty thick walled to have the same stiffness as a 22mm bar (probably 22.2mm actually).
                          It's possible, but not a slam dunk, to make a larger hollow bar stiffer
                          If you privately email me the wall thickness of the hollow bar, I will show how to do the math.
                          Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                          Ground Control Gallery
                          The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                          • Bothfeetin
                            • Dec 2010
                            • 340
                            is looks labor intensive im just gonna go with the 22.2
                            #Treadlifematters
                            • george graves
                              • 20003
                              Oh yea? Come on, lets see you try to prove that one...
                              Originally posted by Matt-B
