I am trying to install my ST rear swaybar, but the instructions and diagram that came with them suck horribly. I know that I have to weld on the reinforcement tabs, but how do I assemble the endlinks? Does anybody have any pics of what the assembled endlinks should look like, or mabey a writup? Thanks.
Installing ST swaybars
i just installed mine no problem. Do you have the directions for them? I can probably snap a few pictures today after work if you would like.
Kyle1988 M3, 97 840, 99 XJ
DILLIGAFComment
the endlinks are easy. One endlink (if I remember correctly), consists of a threaded rod, 2 rod ends, and 2 nuts.
Try and make the best of this....
O=[]------[]=O
KEY:
O= rod end
[] nut
----- threaded rod
the nuts you tighten against the rod ends to hold them in place. Just measure the length of the stock ones, and make these the same.
You then have a spacer on each side of each rod end, which is there to keep the head of a bolt or nut from allowing full movement of the bearing.
hth-Brandon
'86 325es S50
'12 VW GTI Autobahn DSG
'03 540i M-Sport (sold)
'08 Jeep SRT-8 (sold)
For sale:
S50 TMS chip for SchricksComment
