Other options for "tall" RSM?
    • 37832
    Been searching options for a tall rear shock mount so that I can run my Tein E36 M3 rear shocks on my E30. I know that Ground Control makes these but I feel they're a bit pricey at $150. Just wanted to see if there's any other options out there. I'm not saying the GC stuff isn't good but it's not cheap.
    Here's the GC product for reference...
    I noticed Bimmerworld sells the GC tall mounts too. Anybody know if Bimmerworld does free shipping or anything of the sort?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • whodwho
    • Jun 2008
    • 1547
    I was looking at those a while back and then thought you can make something similar with a couple flanges and a short section of tube and use your existing RSMs.
    Might be an option for you?
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • 37832
      I was thinking of going that route too but if there's something a little more reasonably priced I might go for it.
      Grover Beach, CA
      www.BimmerHeads.com
      • Aptyp
        • 6584
        plumbing section at your local hardware store and a drill are your best friends. That's something I'd be doing, quite honestly.
        • nrubenstein
          • 3148
          You know that the GC rear mounts only solve excessive droop issues, right? The fact that the E36 shocks are too long to get any travel won't be fixed.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • einstein57
            • Jun 2007
            • 10780
            What about making some riser plates with longer hardware
            www.gecoils.com
              • 37832
              How do you figure? If I am putting the top of the shock 2 inches higher it will have more room to travel in the E30 chassis.
              Grover Beach, CA
              www.BimmerHeads.com
              • Hellabad
                • 807
                Bear with me.
                I think you might be confusing the GC Hondamount with the GC tall mount.
                They look similar, but can (and do) two somewhat different things. The Hondamount does exactly what you said, it allows the shock to come up through the sheetmetal farther than stock, and allow the shock to move higher allowing more travel. This is possible because Honda shocks are really small diameter, 43mm or so, and the hole in the body is comparatively large.
                The e46 on the other hand, has a 45mm hole in the body and most shocks are 50mm outside diameter, so it can't go up through there. e46 is the big market for those mounts, sold to people "fixing" mashup suspensions.
                The e30 usage of those rearmounts is just a little side benefit when we are using 5 inch springs, on a shock that fits 5 or 6 inch springs (to reduce the droop but allow us to change springs).
                The e30 has a larger 51mm hole through the body, but here are the two hangups with what you are thinking: The pieces can be made, but they will have to be cut out of a two 4 inch blocks of aluminum, so you get to $150 pretty quick, and you can only add about 20mm of travel, because of the angularity anyway.
                So, technically you are correct, but in practice it is just easier to get the right shocks.
                Jay
                ps when I say angularity, I mean the shock goes through the hole at an angle that get tighter on one side as it moves up, until it wedges the shock on that side.
                Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                Ground Control Gallery
                The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                  • 37832
                  Jay, thank you for the detailed reply! Much appreciated.
                  Now I do have this question... Say I do mount the E36 M3 rear shock on my E30 using the GC tall mount. Is there really ever going to be any occasion where I use every inch of shock travel to have to worry about the issue of it coming up too high?
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • Hellabad
                    • 807
                    I would propose to actually modify a hondamount to ft an e30. It's just metal.
