Sway bar end links replacement question
  • sacbmwdriver
    • Aug 2009
    • 422
    So basically I noticed when I make a hard left turn i feel some sort of vibration/unsteadiness but when I turn right it is smooth, Driving on freeway speeds at around 65mph causes no vibrations, so I figure it's not the control arms/bushings and so I lifted the car up and took a look, and the Control arms look fine, but on the driver side sway bar end link bushings seems cracked and old and doesn't look like it's tight as the front passenger sides sway bar end link, so basically I am going to replace both sway bar end links, but my question is should I replace anything else under there? Because the control arms/bushings seem fine. Or would I be okay just replacing the sway bar end links alone ? Thanks in advance
