offset CABs and new control arms. quick ?
  • naynay
    • Feb 2011
    • 23
    I cant seem to get the new control arm all the way into the new bushing.. is there a trick i am missing? ive been jackin with it for about an hour and I am still a half in away from being able to bolt the sum'bitch up!
    quick answers appreciated
  • Dominic49
    • Feb 2007
    • 1373
    needs more lube?
    factory or aftermarket bushings?
    factory or aftermarket control amrs?
    • naynay
      • Feb 2011
      • 23
      control arms from pelican parts..
      offset CABs from turner, OEM m3 offset.. i was afraid any lube would eat the up but i'll try that
        Use liquid soap as a lubricant. Unless you are a real gorrilla (or have one handy) you will wind up driving the bushing home. Twist it on as fas as you can, then use a deep socket or tubing that just fits over the control arm and a hand sledge. As soon as possible after installing the control arms, set the car back down on the wheels overnight to avoid the lube drying with the bushing out of position.
        • naynay
          • Feb 2011
          • 23
          ok, jlevie, that worked like a charm..
          new problem.. the top mount for the control arms.. the balljoint itself is turning as i try to tighten the nut.. it was doing this when i took the old one off, but i just ripped the boot and put some channel locks on the bottom side.. what can i do to keep the center joint from turning??
          • nrubenstein
            • 3148
            Apply pressure from the bottom. Throw a piece of wood on a jack and press the ball joint into the socket. Don't use too much pressure.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • naynay
              • Feb 2011
              • 23
              right on..
              • naynay
                • Feb 2011
                • 23
                thanks guys.,.. got it all back together.. still waiting on the camber plates to show up so i can finalize the suspension, but i wanted to get it back on the wheels so i could see how it sits! its hard doing shit alone but a mans gotta do what a mans gotta do, right? thanks again for yalls help
                • jrobie79
                  • Mar 2006
                  • 2526
                  looks good, what shock/spring setup?
                  1991 318i ---- 308K - retired
                  • Teaguer
                    • Sep 2004
                    • 6167
                    I was going to post my obligatory "Noobs working on e30's FTL!".
                    But after seeing that you are in Dallas I'm going to ask what part of town are you in?
                    I did this very job plus some yesterday.
                    Control arms, LCAB's, and complete tie-rods on a members eta sedan on Saturday.
