Dead zone in steering
  • Sagaris
    • Sep 2009
    • 2243
    One more idea: what about where the rack mounts to the chassis. Anything broken / worn there>?
    • blefevre
      • Dec 2008
      • 4287
      I will check them when I check the flex disc and all that.
      - E30, DSM, Golf R, Mazda 3 Skyactiv
      • glucklich21
        • 1912
        Well I discovered something. I should note it's only like this at certain angles the steering wheel is at.
        Replaced my control arms, inner and outer tie rods, control arm bushings, steering rack, sway bar bushings and end links, and my steering was loose. My E30 p...
        So everyone having this problem go see for yourself if yours is doing this as well.
        • Turd
          • 185
          Tighten up your rack/pinion tolerance. Check bushing. Check all joints for slop.
          • glucklich21
            • 1912
            Yeah I'm getting a whole new assembly when I pull the engine.
            • gverelli
              • Dec 2008
              • 772
              ^^Think I may have that issue, I replaced everything and still have play in the wheel
              G.Verelli
