I have a 90 325is that is pretty much stock except for 15 mm drop hats and 7.5 x 15 Ronal LS wheels. I am not planning on lowering the car. We have replaced control arms, CABs, struts, sway bar links and sway bar bushings. For some reason the 3 bolt holes in the shock towers have been drilled out by PO so the are elongated and we can't find the original center points. Right now struts are aligned all the way in closest to the motor. I am having problems with alignment, it is at about -3.5.
Any explanation for why this was done? How can I find the correct position for the bolts? Are camber plates an option to solve this problem?
