H&R Cup Kits VS H&R Coil Overs
  • bmwdude
    • 268
    My curiosity is killing me. I'm a Cup Kit user, but deep down, I've always wanted the Coil Overs, but the 2X price over the Cup Kit made me choose the latter. Has anyone ever compared the two? Ride? Handling?
  • DEV0 E30
    • Oct 2004
    • 8904
    Coilovers are for someone who wants that adjustability off the shizzle.
    I'd say just strut your stuff for awhile with the cupkit, if you didn't use the coilover system it could end up being a waste.
    Was just curious and looked at what H&R said on their site about the two.
    Cupkit
    H&R Cup Kits are an ideal solution for those that want aggressive looks and impressive handling at an affordable price. H&R's Cup Kits are specially engineered from the ground up with custom-designed springs and shocks that are developed together to work in perfect harmony.
    Unlike competitors spring and shock kits, H&R Cup Kits are not merely a 'matched' spring and shock package, but rather a specially engineered 'solution' with springs and shocks being engineered individually in every application. This takes the guess work out of your spring and shock selection, and provides you with an application specific, precisely calibrated spring and shock set designed to deliver improved handling, uncompromised ride comfort and sleek styling in one precision engineered package.
    Coilovers
    Engineered for street and occasional track use, H&R Coil-Overs feature a fully-threaded shock body (not an imitation sleeve-over) that allows you to precisely dial in height adjustment to achieve optimum weight transfer, or simply get the aggressive look you've been looking for. Featuring H&R's exclusive dynamic damper technology, each shock is engineered to work in harmony with a progressive-rate spring, together creating a finely-tuned suspension system.
    Coil over suspension is the ultimate expression of high-performance handling, and now H&R Special Springs takes this technology to the next level with its new PCS Coil Overs. Like H&R's original Coil-Overs, PCS Coil-Overs are engineered for street use, but have a number of new features designed for the enthusiast who desires a manual shock dampening feature.
    In addition to state-of-the-art inverted damper technology and adjustable ride height, PCS Coil Overs feature an external adjustment knob that allows the user to simultaneously adjust rebound and compression. Nose-diving under hard breaking is virtually eliminated, which effectively reduces braking distance. And unlike traditional twin-tube shock absorbers, H&R's mono-tube gas shock absorbers eliminate foaming of the damper oil, even under extreme conditions.
    RSS Club Sport Coil Overs, are designed for the committed motorsport enthusiast who is willing to relinquish some ride comfort in return for ultimate handling performance. The firmest coil-over in the H&R street line, the RSS is the choice for weekend track and club sport events.
    Equally at home on street or track, H&R coil-overs provide enhanced performance, improved corner-holding ability and a sleek, aggressive stance-without the bone-jarring ride of some less-advanced suspension systems. All H&R coil-overs are hand-assembled in Germany to rigid ISO 9001 and German TÜV standards.
    • bmwdude
      • 268
      Well said, "......the adjustability of the shizzle."
      I'm sure though that the shock itself is a little bit more advanced on the coilever model, over the cup kit's. Like you said, I'll strut my stuff for a few more years perhaps, and then try something new. I'm happy enough with the Cup Kit.
