E36 Strut Perch Cutting and Rewelding
  • Pussy30
    • Feb 2011
    • 463
    I obviously know you can do this on e30 struts but since you can actually pull the cartridge out your not gonna mess up the strut internals by welding it. But With e36 struts once you cut off the existing perch can you put a weld bead lower for the adjuster?
    Thanks, just cant find any info on this.
  • george graves
    • 19997
    subscribed.
    Originally posted by Matt-B
    • Pussy30
      • Feb 2011
      • 463
      subscribed.
      Thanks buddy
      • Pussy30
        • Feb 2011
        • 463
        ummmm bump?
        • Pussy30
          • Feb 2011
          • 463
          no one?
          • Danny
            • 14216
            subscribed.
            • ak-
              • 12422
              My friend did this for an e30 with the cartridge still inside out of laziness and when the insert was pulled out months later for what ever reason, there was a brown burn mark on the Bilstein shock.
              That's all I know from experience with this question.
              Edit: wait no, he got the burn mark from welding M3 sway bar tabs on the housings and not taking out the shock insert.
              1991 325iS turbo
              • Pussy30
                • Feb 2011
                • 463
                Like I'd imagine you would be ok, i just dont know if the heat will mess anything up internally.
                  The welding heat will almost certainly damage the strut.
                  • george graves
                    • 19997
                    Well. What do e36 guys do?
                    Do you *HAVE* to buy the pre-shortened from someone like ground-control? They sell them in the bastard kit.
                    http://www.ground-control-store.com/.../II=812/CA=242 parts from GC?
                    • Pussy30
                      • Feb 2011
                      • 463
                      • bimmer630
                        • 1228
                        welding on a strut can also kill you
