Will camber plates work with 15mm drop hats? Thanks
Drop Hats & Camber Plates
No. They are used in place of each other, not together.
Personally, I'd pay the extra and go with camber plates. GC or Vorshalg will lower you that much and allow camber/caster adjustment.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
they do not work together to my knowledge. I replaced my drop hats with GC touring camber plates last weekend. the spring hats on those plates are modified to work with the plates themselves. most other camber plates I believe are for coilover/2.5" diameter springs so the top-hats will be different than what is needed/used with drop hats/stock style springs/hatsComment
