My steering isn't as responsive as it should be, help?
  • BMC227
    • Apr 2011
    • 448
    Hey, I've noticed that the steering on my e30 isn't as responsive as it should be, it feels like it's "floaty" and also at high speeds it feels very floaty. I've replaced the tie rod assemblies and every other front end suspension/steering component. I've checked the wheel alignment several times and checked everything thoroughly but still can't find my issue.
    Can anyone help me please?
    They call me the frog
    - E30 Alpina C2 2.7
    - E30 Alpina C2 2.5
    - E28 M 528I 3.5 (300HP)
    - E36 M3 S50 3.2 (Euro)
  • Philo
    Ich esse kleine Kinder
    • 3334
    How are your tires? Is this a new problem?
    -tim
    Originally posted by Jordan
    I like the stance
    • bme30
      • Apr 2011
      • 186
      What's the toe in or toe out?
      • BMC227
        • Apr 2011
        • 448
        The tyres are new and i only just started driving the car due to getting it restored. Sorry i wouldn't know what the toe in/toe out is.
        - E30 Alpina C2 2.7
        - E30 Alpina C2 2.5
        • browntown
          • Jun 2004
          • 3524
          If you're sure your rack / tie rods are good - go get an alignment.
          • BMC227
            • Apr 2011
            • 448
            Like i said i've replaced all the front end suspension/steering bits with new ones. It has been wheel aligned several times, camber is 1.5 degrees negative on both wheels etc.
            - E30 Alpina C2 2.7
            - E30 Alpina C2 2.5
            • JeST
              • 639
              What exactly do you mean you replaced all the front end suspension/steering bits? Exactly which components are you referring to? If a front control arm bushing is worn it could give a real shitty steering response and it's also a quick look to see if it needs replacing.
              Current: 1988 M3 - Henna/Black black alcantara
              Guten Parts + Service
              ... When you care enough to only give the very best.
              Previous:
              '87 S50 MTech 1 325is
              '07 DTM Audi S4
              '03 VF Supercharged M3
              '03 Lexus IS300 (615rwhp/512rwtq)
              • browntown
                • Jun 2004
                • 3524
                Sorry, I was just responding to your question about toe in/out. These are specs you would get from your alignment shop.
                • JeST
                  • 639
                  This is a picture for toe in or toe out to give you an idea. Specs should be printed on your alignment sheet (if you received one) and if you didn't receive one I would question the alignment ...
                  Previous:
                  '07 DTM Audi S4
                  • BMC227
                    • Apr 2011
                    • 448
                    I replaced the following:
                    New control arms
                    New M3 offset bushes
                    New tie rod assy
                    New steering coupling
                    New shocks
                    New strut mounts
                    New engine mounts
                    New sway bar bushes + adjustable links
                    - E30 Alpina C2 2.7
                    - E30 Alpina C2 2.5
                    • BMC227
                      • Apr 2011
                      • 448
                      What i meant was, i don't know the toe in/toe out specs on the car at the moment.
                      - E30 Alpina C2 2.7
                      - E30 Alpina C2 2.5
                      • Ian Bowers
                        • Apr 2008
                        • 1120
                        Have you ever driven an E30 before this ? The stock steering rack isn't super responsive, and it has a ton of travel lock-to-lock.
                        • BMC227
                          • Apr 2011
                          • 448
                          Yeah dude i've owned a few before this but my problem is, at high speeds (150km/h) the steering feels floaty.. as if the wheels aren't sticking to the road as they should.
                          - E30 Alpina C2 2.7
                          - E30 Alpina C2 2.5
                          • Earendil
                            • 1662
                            My suggestions would be:
                            1. Don't do 150km/h in a downpour.
                            2. Remove all the bodies from the trunk, and the lead weights from the rear bumper.
                            Otherwise, do you have something aerodynamically @#$%ed on your car?
                            Jokes aside, it doesn't make much sense to me that you'd have a floating wheel at speed, but not driving slower.
                            Oh, check your tire pressure! The only time I've felt "floaty" steering at freeway speeds was when I was driving a truck that had the trailer incorrectly loaded (front end of truck didn't have weight on it) and when someone put the maximum tire pressure in the front wheels of the car :curse:
                            1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                            2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                            I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                            • BMC227
                              • Apr 2011
                              • 448
                              Thought i'd let you guys know that i found the problem, the new inner tie rods that i installed were faulty! so i swapped them over with another set of new ones and the steering is great!
                              - E30 Alpina C2 2.7
                              - E30 Alpina C2 2.5
