GC coils popping
  • RUFFLZ
    • Apr 2011
    • 3122
    GC coils popping
    "popopopopopop" is ALL i hear when im turning at like 2-3 mph.
    when i'm at normal speed, there's no more popping during cornering...don't know what the problem is.
    I was told this was a usual occurrence with GC coilovers and there's really nothing you can do about it, but WTF this is annoying as fuck.
    I have koni shocks btw.
    anyone know what the problem may be?
  • Wishno87
    • 6025
    You running camber plates?
    • RUFFLZ
      • Apr 2011
      • 3122
      yep
      • Danny
        • 14216
        Mine do this too. I thought it was my fucked up tie rod, but I'm not sure.
          That sounds like what happens with plain sperical camber plate bearings. They bind slightly cand cause the spring to "wind up". When the bearing moves you hear a pop. This is completely normal and doesn't hurt anything. A bit of light oil, frequently applied, will help.
          • Wishno87
            • 6025
            +1
            I plan to take mine apart and relube them pretty soon.
            • RUFFLZ
              • Apr 2011
              • 3122
              Cool, good to know it's not progressively wearing anything down or manifesting a problem with the camber plates themselves. Will add oil when I have time, thanks
              • csermonet47
                • Jul 2009
                • 937
                Lucas Red and Tacky is what GC recommends for their plates. Any local autoparts store should have it. Mine did this as well.
                Are Three Vee
                Dad Spec
                • Wh33lhop
                  • 11705
                  I had to add some red n tacky grease immediately as my GC plates were popping from day one. I've had to regrease mine every few months (they are up for it again).
                  paint sucks
                  • ldsbeaker
                    • Aug 2004
                    • 3098
                    Dood. So glad I saw this thread.
                    My e28 does this (GC+camber plates), and it's been driving me nuts since I replaced almost everything suspension-wise...
                    Thanks, guys!
                    Slicktop City!
                    • j0oftheworld
                      • 480
                      Probably the spring binding and un'binding..
                      Even the HR Race springs do that since I removed the spring pads.
                      Jack up one corner and have someone turn the wheel while you watch the spring.. If you see it suddenly rotate a bit when you hear the noise, bingo. :)
                      • Jafxod
                        • May 2011
                        • 1301
                        My GC's and cosmo camber plates do this.
                        • Hellabad
                          • 807
                          Cosmo camber plates dont have bearings that can be greased. GC race plates do have steering bearings that CAN be greased, so ignore what people are saying about grease. It might make it worse.
                          Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                          Ground Control Gallery
                          The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                          • IRON-E
                            • 16548
                            Thanks for steering me in the right direction Kev. I'm having this same issue and it's driving me fucking crazy.
                            Will lube up and report back, hopefully that'll fix my problem.
                            @IRON-E30 aka Edwin:D
                            • Balleristic31
                              • Aug 2009
                              • 4198
                              Would this possibly occur w/ IE3s and billys? I have this same problem and I thought it was my 2 piece steering shaft being loose, so I tightened the big brass nut under the dash.
                              -NICK
