Is it just me or is it SUPER hard to replace front sways
  • ROLLingKING
    • Apr 2011
    • 1169
    I have EVERYTHING apart...new suspension technique sway and hardware, along with my race skids cross brace that shold have been on a hr ago
    Ive been trying to turn and wiggle out my front sway bar for over an hour
    anyone have a video or a trick to get this fucking thing out??
    m20 is plenty. im simply a drifter.
    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
  • DRTSRFR
    • May 2008
    • 1836
    Unbolt the lolipops and it'll slide out.
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    • taiden
      • Oct 2009
      • 178
      Some cars require that the car be on the ground when you install or remove the 'lollipop' bolts.
      If your car is too low to facilitate this, you can try carefully putting the floor jack under one wheel to 'unload' the lollipop and try again.
      Most cars require you to do the final torquing of the lollipop bolts with the car on level ground.
      • HellzMindPlaya
        • 395
        Huh??? The lollipop that is on the back the lover control arm... it shouldn't require it to be on the floor.. only thing that should be needed are a ratchet, a socket, maybe an extension to get a good angle, and a cheater pipe if you aren't feeling manly enough!
        e30 Sold long ago - Too many BMWs since then... For now 2006 M5
